Query: How does TCO work when on uses ones own domain
Hi bubblers,
I understand we can use own domain name in bubble. My query is more related to Total cost of ownership of a solution. If I host my app using my own domain, I would have to consider the cost of the hosting with the service provider I choose as well as the cost of a plan with Bubble. Is this a correct understanding? Pls guide.
Yes that is correct.
Thank You; this helps
I’m not sure what you mean by “cost of hosting with the service provider.” Bubble handles all the hosting for you as part of your plan. You need to purchase a domain from somewhere else, like Google Domains, but there’s no “hosting” you need to purchase aside from Bubble’s paid plan.
Hmmm… yes, true… Thanks for pointing this out.
