Radio Button "this input should not be empty" does not display warning indicator when run
I have 2 radio buttons on a form that I want to begin with a blank value and require that the user provide a “yes” or a “no.”
I’ve set the default value to blank and selected “This input should not be empty” - when I test leaving the radio buttons unselected, the workflow does not run. But there is no indication why. --Unlike the required text input fields.
Is there any way to convince the radio button to display the red "hey - I’m a required field?. :man_shrugging:t2:
-I guess I could create a separate workflow that runs when the radio buttons are not selected and run an alert or something. - But Bubble has conveniently built it into the text inputs. :man_shrugging:t2:
many thanks for any help!
Tom
erg - tearing my hair out. trying to run a workflow if the radio button is “empty” or “invalid” - does not work.
