Repeating Group Properties are not visible on front end
Hi Everyone,
I am a beginner and learning bubble. I am using repeating groups and I have selected the data source but on the front end when I preview the data is not visible, I have created a short loom it would mean a lot if you can take a look and guide me where I am missing the step or anything.
hello @shahabupwork2 , can you show the datasource of the RG?
The most probable cause is the RG’s Data Source is not retrieving any record. Reasons for this
  1. Your DB is empty
  2. You are using a too restrictive constraint
  3. Privacy Rules prevent the user to find Property records with a search
We can help you more if you share your RG’s Data Source, DB table for Properties records and Privacy Rules for Properties datatype.
Hi @hanan1,
Thank You so much for your response, please have a look and let me know if you have any other questions for me:
I will be looking forward to your response.
Thank You!
@hanan1 meant the Data source of “Repeating Group properties”. You didn’t get to show it in your last video.
Also, it would be nice to see the Privacy Rules for datatype Properties.
thanks! still, we need to see where the data is coming from to be able to help you. can you maybe select the RG itself and take a screenshot?
I am not sure what to select here because this step is missing in tutorial
We need
Please show us this element
