Good afternoon!
Can you tell me how to set up a repiting group with horizontal scrolling on a mobile device so that it looks like in the picture below?
That is, that despite the size of the mobile device, the part of the card in the row is always shown, so that the user understands that the horizontal list should be scrolled to the right.
That is dependent on the minimum width of the RG cell, the device width, elements that are inside of the RG cell widths etc.
When setup, there will be times when depending on your settings, the last item in the RG may not show only a partially and could be full, so your user may not get the sense that more are available.
You can play with using dynamic width values (a few plugins available) to set the width of the RG cell elements to always show a partial last item based on the device width.
Can you please tell me which plugins you are referring to?
The above is one that I am partial to as I made it. There are others that do similar things.
