Hi! Repeating Lists and Drop Downs will only work in preview mode. Did i do something wrong? thanks!
example: https://bubble.io/site/repart/join
Hi. What do you mean by “work”? Loading data? Then yes, they’re only supposed to work when you preview them, to keep the editor lightweight and nimble.
https://bubble.io/site/repart/version-test/blog?debug_mode=true
It switched to live mode, and it does not work. anything that needs the database refused to load. however, I can see it in “preview mode”
thanks!
If they are populated with data, then the live database isn’t the same as the test. It may be empty ?
Thanks! that worked. I did not know that i had to copy from dev to live.
