Reset Data or inputs help
I have a form with multiline inputs.
The multiline inputs have initial content from the database.
If i use Reset Group or inputs it does not work as the reset takes the element back to its initial state which shows the db contents.
Is there a way i can delete the input contents ?
You should use states. Use the “display data to a group” to send the database element to your form. Then all your inputs takes their initial value from this group. When the form is submitted, send an empty state to the group, that will cancel all values for the inputs.
Thanks for the reply:
Being a bit thick but how do i send an empty state?
