Runaway development work flow
I had a backend API workflow that I triggered that ran away and consumed a lot of workflow units. It was in development. Will this be charged to my plan?
Yes, you can see the metrics in the logs tab of your editor.
Oh, I can see the metrics. I’m just curious I believe that they charge you for live and development correct. So if I went over that I’m going to be charged.
Yes. Sometimes if its a one off accidental run they can waive it if you contact support
For your help. I will contact Support.
