it would be nice if right clicking an Edit other… action under the Edit one at the popup menu of an element in the designer (or else to do it if I shift+click or right click the Edit action in the current popup) showed me all elements under the pixel position, with the top one preselected in the list. That way I could select an item that is underneath say a transparent button
The closest thing to that is the manage children actions, even that doesn’t cut it. I should be able to select any of the children from that manage children
