Selectively reset an input element
I am very new to Bubble, so I apologize in advance if this is a dumb question. I have a button which saves a part number and adds a component to a repeating group (by saving to the parent type). I would like to reset the component input element but not the part number input element. The reason for this is each part number can have a lot of components and I have the repeating group set to only show the components where the component is associated with the part number in the part number input element. Help!!!
put the input element into a group…then you can do a workflow action to “reset data” on the group…this will reset the input
Perfect!!!
You are the best! THanks!
As a way to help future bubblers mark my reply as solution so future bubblers will know this thread has an answer to the question.
Cheers
@jowacoop you should mark his first reply as the solution :wink:
Thanks for the tip, @boston85719.
