Sidebar Menu - Mobile Click-Through Issue
Hi folks - I’m having an issue with the sidebar menu on mobile. It’s apparently allowing items BEHIND the menu to be selected when items are touched on the menu. For example, if there’s a clickable item sitting behind the menu when it slides open, touching the menu item actually triggers the item behind the menu instead of the menu item, itself. When no clickable item is behind the menu, it works fine.
Is there a way to reconcile this? I thought I may be missing something simple (perhaps I am?), but I can’t seem to locate any features. The menu is within a reusable header, while the menu slides out over any given page.
Thanks for the help!
