@levon Is it possible that this will be fixed or is it a lost case. If it is a lost cause, i will need to remove all the slack functions from my app before launch.
Hey @ryan8 i’m afraid there’s not much we can do except rebuilding this plugin entirely with code which wouldn’t be a high priority for us right not
Maybe you could meanwhile use zapier or integromat to use slack in your app?
okay well my app will only work with an oAuth setup… that is a bummer it cant be done anymore and slack changed things like that.
You might look at the auth0 plugin that was created recently.
Auth0 natively authenticates with Slack.
