Have been working on this for a while and I can’t find a solution.
I need to open a fullscreen popup with scroll, but in IOS it makes a kind of jump and it scrolls the page content, instead of the popup content.
Anyone found a solution to this? Bubble doesn’t solve this automatically.
Thanks
You have to use a group instead popup. You can create a reusable element.
Thanks @ualdir , but that doesn’t solve the fullscreen scroll issue in IOS.
Access this link on IOS https://vanmo.com.br/mobile2 and click in "Politica de privacidade"and check if is like that what you want?
Thanks for the example @ualdir, but I can’t properly test it as the page content is smaller than the popup content. Do you have an example like your homepage (a lot of content) with the popup showing there?
Thank you
