Stripe Initialize Problem
Hi
Has anyone solved the stripe workflow initialize problem yet.
Anybody out there that can help?
Thanks
Are you talking about webhooks?
Sorry - Yes I am
Apparently Stripe have removed the test webhook button and the only advice i get is to install the stripe cli which is too much for me.
Tino
The simplest way is just to run the event in question (depending on what event it is you can either do it through your app, or through some of the other Stripe developer tools)…
Which event are you trying to trigger?
I try that and let you know what happens.
Thanks
