Two issues but not indication of the issues in question
I’ve not seen this before so hoping someone might be able to steer me. Attempt to deploy to live and i’m met with “You cannot deploy your app because there are 2 issues you need to fix before going live…” yet there is no usual indicator of the issues in question.
I have the same issue, but I can’t update either.
i need help please
Ive filed a bug report
If you have refreshed your editor and you still don’t see the issues, you should submit a bug report.
If you really need to deploy, you can do this, but I wouldn’t recommend it.
Yep and thanks done all the usual…different browsers and the like. Bug Reported submitted.
