Im trying to make it so when you change the value of a text and data using a dropdown, but there is multiple of the same choice, And it doesnt change it exactly. Im using a Yes/No Data Please help!
Is there a reason you can’t just use a toggle switch here rather than a dropdown? You can then autobind and remove the workflow completely. Then conditionally change the Warrant Active : text between yes and no.
Got everything, Thanks for helping me out with this. This will be useful to me in the future!
