I am using group focus in repeating group through reusable element but it is not working it is not showing in the middle of the row in repeating group, it is only showing on first row and the last row.
use reusable element that contains the group-focus.
Hey @shahnavaz ![]()
@exontract is right. You can find an example of that below:
@Huseyin from Flusk | Discover the #1 Security and Monitoring Tool for Bubble
@exontract already using
Yes you said that already, my bad.
I think some other element is blocking the menu (3 dots) icon when it is in between the first and the last. I am guessing even the mouse doesn’t turn into a hand icon meaning it is clickable?
If that’s the case, maybe play with the elements around this menu icon. Hide some icons around it to make sure they are not blocking the menu icon.
Hey @flusk thanks, but i tried to remove other icon but still the same issue persist and if we hovering the cursor cursor icon turning in to hand.
I think you open the example in the post I gave side by side and see if there are any differences between yours and the example. Like the place/layout/workflow of the groupfocus, the button, etc.
This is the best I can guess. There should some be small thing.
Also make sure there are no conditionals in the rows in between the first and the last.
hi @flusk it’s done there was condition issue.
