Where is the help reference material and documentation?
Hello,
Can someone tell me, how do i navigate to the help reference material to read it?
I understand while using bubble, there is a link to reference always poping up, but that onl goes to that one point, and does not let you scroll, so i want to read the material
Secondly, the reference is that, a reference.
Is that other simpler example documentation that i can also read.
I’ve watched the videos, and what im really looking for is how to use bubble to call an API
Check this out for api connector API Connector - use most JSON APIs directly from Bubble
Click “Learning Center” above this page. From there, you can access the reference and manual.
