Workflow triggered on RepeatingGroup element click
Hi Bubblers! Running into a problem I’ve never seen before.
I have a Repeating Group. Within that Repeating Group, I have a button for each row. I then have a Workflow, triggered on when that button gets clicked.
However, that doesn’t seem to be happening. Nothing is triggering at all when the button clicks. Even in “Step by Step” mode in debug, nothing is even activating when the button clicks.
I’ve also tried it as a Text element instead of a Button—same result.
Any ideas?
see if you have not made the button unclickable. from properties. and also check if something is not above it, previously it happens a lot, but with the responsive engine, it only happens in Align to parent.
