Is anyone suddenly experiencing instances of workflows NOT successfully setting custom states?
These workflows worked fine yesterday. Wanted to hear from others before I submit a bug report.
That might be the problem in having. I posted here a couple of hours ago.
Sounds like what I am experiencing. I have custom dropdowns and those are the workflow that are having issues.
What OS and Browser are the problems on?
Mac
All browsers: chrome, safari and firefox.
Earlier states would occasionally stick in Safari but not anymore
Odd. My problem is the same. I know the custom states are not being set but only on Windows 10 and Chrome. Everything else is working for me. I just can’t fathom what’s going on and I’ve spent a ton of time already. Hope someone else chips in with ideas.
@eve , could you kindly check the patricia’s test page to verify this
@muneer.hameer, @patricia, if you’re experiencing trouble with your app, please do file a bug report so that our team can assist!
I’ll do that now @eve. I’m not convinced it’s not something stupid I’m doing so I hopped to check that with other bubblers on the forum first but I’ll post a big report now.
I believe I am experiencing the same.
I have the following workflow set which includes settings the state of a reusable element to Opened Yes.
Immediately after, the following workflow automatically runs when I don’t believe is should because it should only run if the state is Opened No.
I could have just done something wrong but it did all work until recently.
As others appear to be experiencing something similar, i have filed a bug report based on the above.
