ZQ Fuzzy Search & Autocomplete | How to make it work with first letter in input?
Currently, Fuzzy search plug in displays results perfectly when I type in at least two characters into input. But no results display when input’s value is only one character.
FWIW, I also have Input Watcher plugin installed, which helps a lot with speed of displaying results, but does not solve issue of displaying results with only one character typed into input.
I’ve tried playing with Fuzzy Search’s threshold. No luck there. I also tried creating a new data field for my data types that are each just the first letter of each data type and then adding those first-letter data fields as one of the “Fields to Search” for the Fuzzy search. No luck there either.
Hello @shapirojojo,
Thank you for reaching out to us.
It looks that the issue you are experiencing may be related to a specific setting in the plugin element, particularly the “Exclude Terms Shorter Than” field.
Could you please try setting its value to 0 or 1 and let us know the outcome?
If the problem persists, could you provide more details about your setup? We would appreciate screenshots or a screencast of the plugin element and any related workflows, showing how the problem manifests in your case when there is 1 letter and when there are more. Additionally, please include any error messages from the browser console.
Thank you once again for your cooperation, and we look forward to your response.
Best regards,
Zeroqode Support Team
This was the solve!! Thanks so much.
JS
Hello @shapirojojo ,
Thank you for the message and keeping us updated. :pray:
I’m glad to hear that adjusting the “Exclude Terms Shorter Than” field resolved the issue you were experiencing, and that everything is functioning smoothly now. Please don’t hesitate to contact us whenever you have a question or need assistance with anything—it’s always a pleasure to help.
By the way, if you’re enjoying our plugins, we’d really appreciate a review from you. Just go to the Plugins tab in the Bubble editor, search for the plugin by name, and give it the stars you feel it deserves. Your support is incredibly valuable to us!
Thank you once again, and wish you a fantastic day ahead. :dizzy:
Best wishes,
