I’ve been scratching my head trying to figure this out… Any advice on how you’d implement something like this?
Thanks
Dom
Thanks
Dom
Slider should work as a native element.
Otherwise a list of numbers from the Toolbox Plugin and a Repeating Group.
If one is going to do this a lot you could also create a data type called “Rating List” or similar. It should be like this:
Then use App Data tab to create just one of these things like this:
Now you have a thing in the database that always has this handy list of integers 1 through 10. (Note: there should always only be one of these objects. You’re making a system-level variable here, essentially.)
Then, to use this thing, just do a search for it. Since there’s only ever one you can take :first item and don’t need to worry about sorting. So here’s an RG where we use that as the source:
(That text element just displays “Current cell’s number” - we could also use “Current cell’s index” as they are the same values in this scenario.)
In run mode:
And geez, this is so easy, let’s just finish the whole thing:
Take that text and right-click it. Choose “Group elements in a group”. This’ll give us a group we can expand to act the “selector” for the cell. We’ll use that as the thing to catch user clicks. Group is like this:
And that text is like this (note “this element is not clickable”. That’s important. We don’t want the text to intercept clicks, only the group:
Now let’s put a click action on the Group Rating Selector. Click Start/Edit workflow on that group. What we’ll do is when clicked we will store that group’s number in a custom state on the RG. We’ll call it Selected. The action is Element > Set State. You can interactively define this new state in the dialog box:
Now let’s style up that Group a bit back in Design mode. We’ll use conditions to set a hover state and also light up the group in a different color if that is the cell that has been clicked (and thus its value is stored in RG’s Selected state):
Here’s how that looks in run mode: The user is hovering cell 3 and has previously clicked cell 7 (the number 7 is stored in the RG’s custom state called “Selected”, see?)…
Done!
Now you can do whatever you want with the RG’s Selected value. In my case, I’ll just display it in a text. But obviously you could have the Group’s click workflow write that value into some thing in the database or whatever you need. Here’s an idea:
In run mode it starts like this:
And then you click “10”, because this is a freaking awesome forum reply:
Would I just “hide” the numbers if I don’t want them to show? Originally I had put icons to act as the clickable objects set as little circles. I want to sum up the results to apply to an algorithm. It just needs to be a repeating group right?
Gabby JUST posted a video doing the exact thing Im attempting to do. I think its VIP access (membership eyes only), but if you stumbled onto this thread you can check out her video here. Very much worth the monthly subscription.
Cheers!
I was literally looking for this exact system as I am building a project based learning g platform. Kudos for the detailed walk through!
JB
