1 issue to fix - not visible
Hello
I m having a issue to fix but i cannot see where:
Anyone else has the same?
@emmanuel - can you maybe help here?
I can’t deploy the app because of this error and i don’t know where to find and fix it :slight_smile:
i found the error but maybe there is a bug somewhere here. Below you can see more
For stuff like that screenshots aren’t enough. Please file a bug report.
I’ve had the same problem for the last few days. Bug report filed.
@emmanuel here can be “hidden” errors when the input fields are hidden and not empty.
For instance if you define a Custom Event with a type of thing and you trigger it. If later on you make the Custom Event Type of thing - free, the issue checker still considers the Data you’ve definie on the trigger action, whereas the data input is hidden.
Hope i’ve been clear
A bug report would be more clear :slight_smile:
