I find the process of building user-facing, frontend forms within Bubble cumbersome. For example, I have a very long application form for new users. If I need to add a new question to the form, it means I have to move all the groups down on the page, expand a group, drop in a new text area, and wire it up to save the data. I would love to be able to build forms for Bubble similar to how we can with Typeform, Google Forms, etc. I’m considering looking at using a 3rd party tool to manage all intake/application forms and just send the data back to Bubble. I am wondering, does anyone else struggle with this or am I missing something? What’s your solution?
Check this sample out by @edtyli9
This is primarily for frontend or user-generated forms, right? I’m looking for something that’s enables a better way to design forms as par of an app and is part a write/edit workflow. So not necessarily a survey, but a form to edit data on a thing.
Typeform/Airtable integrations could work, but don’t really enable editing of data.
Yeah, I’m not that sure how you would connect the two together but maybe there is a way.
I guess I’m not understanding fully what you are trying to do.
As for moving groups down the page, a solution for that would be something like this:
I normally add spacers (collapsable groups) in-between groups on the page. That way, if I need to add something later, I just make the spacer smaller. Then I can fit another group or input in, if I need to, without modifying everything else below it on the page.
Does that make sense? Hope that helps a bit at least.
@romanmg has the solution you are looking for.
She can explain it better than I can, but basically you will need to create an admin area where you can create/edit/delete questions for your form in a templated way. The questions become their own datatype. You may want to include question types (text, multiple choice, number, etc.). This way you can quickly add and rearrange questions and save/retrieve data automatically.
Here’s one example of setting up quizes using option sets. This idea easily ports over into using DB things and letting users create/modify their own
