An Element is hovered Issue
Hello
I have two apps. One copied from the other
In the workflow on a page for the original app (growth plan) I can create a new event when an element is hovered
On the other app I can’t.
The pages are exactly the same and I really don’t find when the issue came from.
For sure It can’t be the plan difference.
What the workflow do when it works, when a group (in a repeat group element) is hovered it put the cell index in a custom state
I haven’t come across this event before and generally for this use case, I use the do when condition is true and put the element is hovered/not hovered in the conditional for that event.
However, in this case, are you sure this might not be reflecting because of a plugin that had this action? (low probability but you could check this out)
Hello
tks for your reply
No there is no plugin on this page…
For the do when condition is true I can’t use it because the element is in a repeating group and bubble don’t propose child element
