Booking System Question
Hi everyone,
I’m looking either a plugin or external API service to allow users to have a unique calendar where they can create available appointments (like in Calendly), which we can then show in Bubble (hopefully as a calendar embed).
Do you have any suggestions that aren’t $100/mo +
Reece
I think Calendly uses this API, check it out: Scheduling Bookings For Multiple Users with Timeslots (Too Much Data?)
@help are you only looking for either a plugin or API?
You can also build the whole calendar (availabilities scheduling + display available time slots + bookings) on Bubble - happy to show you how I did it if you’re interested. You might find that helpful as well: [Tips] Let Users setup their daily availabilities
Thanks a lot! That would be awesome -I’ll drop you a pm
Thanks - we’re needing multi-user support which is too expensive
I’d love to know what you decide to do @help. Having the same problem
Looping in @ambroisedlg who is the genius behind our system, I believe he can help on a consulting basis
Have you seen this?
Thanks for the kind words Reece! @Boost feel free to reach out if you want my help
