Some places, click is not working.
For example, clicking on LogOut does not work in the following page.
If I move the location of the button, it works.
Similar problem with the calendar on this page. click works only for some locations.
Can someone please suggest what could be wrong.
Can you provide a sample login username and password? The issues appear to only exist when the user is logged in, as I don’t see a calendar or a logout button.
login: pp2@pp2.com, passwd: pp2
Seems like this problem is there on all the pages of the app.
Click does not work on part of the page (to the right).
Can someone help me with this ? I am stuck, not able to figure out what the problem is.
Based on what I can see, you have some hidden or invisible elements covering up parts of your page. You’ll need to find those in the editor and remove them, that should fix it.
Yes, you are right. There was hidden floating group created by mistake in one of the reusable elements. Removing it fixed the problem. Since it is in reusable element, same problem was showing up in multiple pages. Thanks for the help.
