hello everyone , I need help
How can I create a comment system wich refer to each item in a repeating group. Like facebook comment system under each post
You need to create a nested RG, The main RG is your list of post then inside that add another RG which is the list of comments
You need 2 tables in your database.
On the front end you will need to create a nested repeating group. The outer group displays comments that have the “Parent comment” empty and the internal repeating group will show comments that have the parent comment in this field
I hope this helps.
If you have any questions do let me know ![]()
