Hai All,
I want to migrate the users data of the bubble application to another application. Also can i get password of the existing users during the migration. Please suggest me on how to migrate the data. Thanx.
You don’t have access to the users’ passwords. The only thing you can do after migrating the data is to run a workflow that will send to every user an email with the password reset link. You can customise this email explaining why it is needed.
If you are building the new app from scratch, the easiest way to migrate the data could be just make a copy of the first up and then delete everything in the new app and keep only the database. If it is not the case, then you would need to build a set of recursive backend workflows that will use data/workflow APIs of the both apps and transfer data this way.
