Hi there!
I’m currently working on a bubble site. But it has a problem!
I try to go to another page, but it requires data. Well, in preview, it works fine without filling in that data.
Could someone help me out?
It’s saying there’s a mismatch between the type of data your pages are expecting to receive, and the type of data you’re trying to send (e.g. the page content type is Kmar, but you’re trying to send User data to the page instead).
If it works fine without the correct data then I suspect you don’t need to set a content type on the page.
Well, I need to give data…
Thx for the fast response btw <3
Then give it… just make sure it’s the right type of data.
(if you page needs data and you’re not sending any then the page won’t work correctly. If it works, then you probably don’t need to send any data).
But idk how to give the correct data…
It needs a “Kmar” data, but idk what kind of data that is. When i do “current user’s Kmar” it says its a yes/no.
That doesn’t make sense - you must be doing something wrong…
Without knowing what your database looks like it’s impossible to say what, so feel free to share some screenshots if you want some more specific help.
Oh wait it works now, I do “Current user” and the errors are gone. Thx for the help <3
