Happy new year and thanks for this forum.
I’m trying to do something that - I’m sure - is pretty basic, but I simply couldn’t find the appropriate words when looking for old topics.
Create a state that will hold the current section (can be a text)
create the tabs with each tab that set the state for the current tab when clicked
the section are groups with " this element is visible on page load" unchecked and “collapse when hidden” checked. On each section set a condition that when the current section state is the right one the element is visible
All clear, except one question on your bullet point #3:
So if I fully use the new responsive engine, this means that the 3 groups corresponding to the 3 tabs would basically be appearing as a column (one above the other) in the editor, right? As i can’t overlap groups…
And thanks to the “Collapse when hidden” it would work, right?
Yes, no need to overlap the sections.
Keep them in a container group set to column layout. If you set them to collapse when not visible and show only one at a time the final effect it’s like your example
