Dropdown of Things is not referencing in create taks
You know what - You actually helped me a lot. Thank you so much!
I solved my issue - if bubble doesn’t want me to create Roles and Goal together with tasks for unknown reason - screw it.
I set tasks_role and tasks_goal to role and goal datatype, set both dropdowns to evaluate to the same, and hidden them, if the parent group task is empty.
Now I can create tasks with title, description, and Eisenhower quadrant and then set goals and roles by editing a task.
I FOUND IT!!!
I was editing the WRONG workflow!!!
I forgot, that the workflow is not the same to Create or to Edit!
Thank you so much Miguel!
:joy:
Finding your phone was in your hand after being searching for it all around your house must kick in a similar way.
Happy to help :smiley:
