I’ve had a hard time reproducing this one consistently, but there’s an issue when adding elements directly to the elements tree. Not everytime, but sometimes.
After all this week of using it, my conclusion is that it is worse than the previous one.
It’s faster to transition from one page to another, but it’s slower for any other action (add a condition, work with workflows, work with privacy rules, etc.).
I disabled the function because for me it is more important to EDIT quickly than SWITCH pages quickly.
It’s in early access and hence there will be issues. The point of this EA is for users to try this new feature to submit feedback and bug reports.
I tried it, it was a speedier than normal mode but I feel like there’s some sort of memory leak somewhere that makes the editor slow down earlier than in normal mode.
I would love to be able to explore it and help with bug finding but I don’t have the time right now.
I basically work for Bubble for free lol.
Great news! I think the new features that are coming are incredible. However, I’ve noticed that Bubble hasn’t addressed some recurrent customers feedback, such as:
Why are old problems still unresolved while focusing on less urgent issues that don’t provide immediate value? I share this concern if Bubble team may take it into account.
However, at this moment, do you think it is possible …
to remove the “AI Bubble pop-up screen announcement” from the list of pages?
It appears every time a new page is loaded, consumes memory, and may not be appropriate if Bubble aims to enhance the speed of the editor experience, both in the current version and the new beta.
Thank you!
Afraid to use issue_checker_of combined with this , has anybody tried it ?
I can confirm this from my own experience.
I prefer to wait a bit longer on page load, instead of having a delay for each other action when working on the page.
Hi everyone,
I’m Milo, the engineer working on this project. Thanks to everyone for testing it so far! I’m working on an update today that should improve some of the leakiness in the editor.
Also a request for those reporting specific issues: if you can send me a screen recording of what you’re doing when you get the issue (and ideally also a screenshot of any errors logged in the console).
Thanks,
Milo
Thanks @milo.m
Good to hear directly from the engineer working on it.
In my experience memory leak type of behaviour is indeed there. After some time editor goes bad.
However, now that you are saying that you have worked on an update, we’ll keep a watch to see if it improves. Sending screen recordings/errors etc have been useless in past as our messages are declared as not reproducible or one-off etc. Hope that won’t be the case in future.
Hello, I tried this new feature and encountered several bugs and an improvement to speed + less window crashing…
Bugs:
- when trying to sort a list of texts in the expression builder (no parenthesis) I kept getting the list contraints window instead of the sorting window
- changes did not auto save, the saving text stayed on “saving…” and never updated to saved or to the error state which tells you when the changes are not saved (this led to me having to go back and redo a lot of work because I didn’t notice this behavior for a while
- switching elements / data source changes took longer to become active to save or even open the pop out windows for when changes are made
Hi everyone,
We’ve released more fixes for the reported issues. Please re-test and let us know if you encounter any new problems (sending screenshots of error logs are always really helpful as well)!
Thanks,
Jennifer
Hi @milo.m & @jennifer.javier , I ran into this just now: when using the &autorunnew=true parameter, Repeating Group constraints weren’t showing the Dynamic Expression.
With it on:
With it off:
It is not about &autorunnew=true , I have encountered this too allergens = header2 A’s my condition was like , and I only use issue_checkeroff
Hey @janiece.lincoln , it realy improves the snappiness of the editor, so that’s greate!
But as @davidb pointing out, when working in nested constrains, the newautorun prevents me from adjusting filter on the second layer.
When i remove it, it works just fine.
Keep it up ![]()
Why not use feature flag for this?
They have
When using the new feature it actually makes my app uneditable with constant crashes. Might be a unique case but wanted to bring it to your attention. @jennifer.javier
I have an app with about 100 reusable elements, and with this feature enabled, it typically takes around 30s (and up to a minute) for the list of reusables to appear in the editor when the page is loaded / refreshed.
Additionally, a slew of console errors appears when the editor loads…
The page is loaded message appears before the reusables have loaded. In the above screenshot, for instance, the actual time it took for the REs to appear is longer than the 29 seconds depicted. I’ve actually been timing it with a stopwatch.
Anyway, it’s quite noticeable, as I usually have several editor windows open and frequently refresh them throughout the day.
Really not liking the large amount of critical bugs being reported, hope the new editor doesn’t turn out to be like the beta expression composer (begrudgingly rolled back).
Within 10 minutes, only one Chrome tab(bubble) uses around 2.8 -3.5 GB of memory. And my PC memory is 4 GB. By only one Chrome Tab, Which results in:![]()
