Elements on pages aren't clickable because of HEADER. Need help!
hello everyone!
I built a header and because of a menu that appears when hovering, all elements aren’t working ( i guess it covers them up, as when i delete it - everything works fine)
Here is what doesn’t work
here is the culprit!
Please help me as I can’t move forward in the app right now and feeling a bit stuck.
I guess it has something to do with type of element I am using for the menu, but I am not sure what exactly it is.
Will really aprecciate help and advice as I want to figure it out already! :innocent: :slightly_smiling_face:
the text is not clickable since you’re navbar is to big… you should add a floating group for the profile section, so when someone presses there avatar, the floating bar will be exact there.
atleast… thats how I did those things
Thank you so much for reply!
A lot of people mention focus groups for menus? Do you know anything about it and what’s the best thing to use in my case?
