The dropzone knows that a drag/drop group was dropped on it, but I don’t see how to reference the group that was dropped in the workflow triggered by the drop.
You could search it in the value sec
I think you’re looking for Current Workflow’s Thing? In your screenshot under current workflow image.
So you don’t think I’m supposed to reference the group itself?
It seems weird for the drag/drop group and the dropzone group to be paired up in the plugin, and to work together, but for the dropzone to not be able to reference the drag/drop group that just triggered its workflow.
