Hi all - i’m, hitting an issue and it looks like someone has resolved this before, but I cannot resolve mine.
Basically i have been trying to build a mobile menu (which has been really annoying - there must be a better Bubble way to do this). I have 2 group focuses. One appears when the user selects the hamburger menu (it is linked to the ‘x’ icon since that is what displays when the hamburger menu is clicked based on workflow), and the other appears when “Medical” within the first focus group is clicked (also is linked to the ‘x’ icon).
However, when the hamburger menu is clicked, the first focus group is appearing in the top left corner. When Medical is clicked, the second focus group appears in the correct spot. They both are linked to the same element and have the same offset - any ideas on why this might happen?
Hi, can you give more detail. What are the workflow you have when someone click the menu icon. Juste to make sure the Group Focus #1 is not bind to an element that collapse when hidden.
Hi @eliot1 - so this does like 80% of what id like it to do. For the best user experience - tapping the ‘x’ icon should close the menu and change back to the hamburger menu icon. Any suggestions on how to do that?
With the method describe above it should work as you want.
The toggle action works both ways:
1st click, it opens the menu and the icon change because of the conditionnal group focus is visible
2nd click, it closes the menu and the icon change back to the initial value because the group focus is not visible anymore
But I highly recommend that you use only one group focus. And use a workflow with the toggle action too, to show/hide the 2 rows of the medical section. Instead of using a second group focus.
Your Element Tree should look like this:
Group Focus Menu
Group Animals
Text Animals
Group Medical
Text Medical
Group SubMedical (not visible on page load, collapse when hidden)
Group All Medical
Text All Medical
Group Health Checks
Text Health Checks
Group Resources
Text Resources
And the workflow:
When Group Medical is clicked
Toggle Group SubMedical
