Groupfocus not showing correctly when using "Animate" and "Show/Hide" on the same element
In my application, I have a GroupFocus behaving in a strange way.
I make the group appear using the “show an element” workflow. Then I hide my groupfocus using an “animate” workflow.
The unexpected behavior is that when I try to show again my groupfocus, it will not properly show up on mobile. It will have a strange position offset, and it will have also a very, very low opacity, so it will be almost transparent.
This will happen only on mobile.
Temporary workaround: just use “Animate” both to show and to hide your group.
Sharing here in case anyone else faces a similar issue
