Dear All, could you help me?
I really need (very need) your help in order to create a thing from selected items in a repeating group with a single action workflow.
This repeating group get data directly from an external MySQL database.
I’m already set a custom state to select and deselect the items.
However when I try create a thing to save/storage in the Bubble database, I don’t know how.
Thanks a lot.
André.
Please share some more info or some screenshots
The more information, the easier it is for us to help.
Hey @solutomn, not sure if that exactly fits your use case, but here is an example:
Demo: https://ambroisetestapps.bubbleapps.io/version-test/rg-select
Editor: https://bubble.io/page?type=page&name=rg-select&id=ambroisetestapps&tab=tabs-1
Let me know if that helps
Ambroise
Need extra help?
Book a free 15 minutes call - happy to help if I can
Thanks guys
I’ll try to get images to explain better and I’ll see the examples links you gave me.
Rgds
André
@ambroisedlg,
I will try using the “set list” option as you did in your tip.
I going to back here after that.
Hey guys,
Unfortunately, I did not get do that.
It would work if I would pass the editor link here, in order to you check?
Thanks again.
André
Hi guys. I am a newbie with Bubble and loving it. I am building an app for services on demand. I am trying to create a thing from a repeating group showing categories of services. How can I set up to create the thing? Kindly advise from the screenshots below and I also avail of the links to the project. How can I set the Category?
Project: https://servicehubke.bubbleapps.io/version-test?debug_mode=true
Editor: Servicehubke | Bubble Editor
@ekhangati Hello, you need to have a field under service called ‘category’, its value should be the Category type which you’ve already defined.
Hi there. Thanks for your response. I think I got it the way you suggest. Where I am stuck is how to save the category to the database when the user clicks from one of the categories from the repeating group? See the screenshots below.
