Help for a 1 click setup
Hi everbody :slight_smile:
Im looking into building a membership site.
After my customers signup i want them to able to send their information via API to multiple places.
So here is the flow:
  1. Customer signsup with his name, email, phonenumber ect.
  2. Customer goes on the membership spages and finds a product/service he likes. In order to get this product/service he has to click on a yes/no field(GDPR) and also click on 1 button (get access).
  3. The moment he does this, all his data will be send to multiple ekstern clients via API instantly.
How would you go about this?
Thx in advance
Should be pretty easy.
Step 1 and 2 are fairly easy, do some tutorials if you need help there.
Step 3, you can do multiple API calls in a workflow, API connector, Plugins. Whatever is convenient.
