I kind of just threw it out there that Privacy rules were your issue, so I would check the Privacy tab and see if the User type has something like “User can only see their own data” because that would limit that repeating group to only showing your current logged in user
This action is used to sign up someone else and email them a login link for example (notice it doesn’t ask for a password). But this doesn’t mean your current user would have access to that new user’s fields with the default privacy rules
The sign up action already has built in functionality to check if the user’s email was taken already, but you want to check for first and last name as well? Users can have the same name and Bubble can tell the difference between them
If you want to change the email then you can use the “Update the user’s credentials” action and it also has that built in email checking function.
If you really want to prevent the same name then your Only when
statement should be Search for Users
with a constraint First Name = [Input First name]
and another constraint Last Name = [Input last name]
then after the search do :count is 0
But even if a duplicate first and last name user existed, privacy rules could prevent that search from finding them anyways.
The privacy rules can be modified though of course to fit your needs but the default is like Twitter where users can’t just read all of another Users fields except for maybe their names
Or just delete the rule while you learn how it all works
