Help sorting data (frontend)
So I’ve tired myself out trying to think of a sulotion,
Here my problem:
I have 2 data types (category) (Item) I would like to show all items with x category under x category then repeat next category all items.
By the way there can be 3-25 category with each category having 1-25 items
Here is a placeholder of how it needs to work (menu).
Not quite sure what you are showing us with the link there.
Are you thinking of showing the repeating groups as:
Category 1
  • item 1
  • item 2
  • item 3
    etc…
Category 2
  • item 1
  • item 2
    etc…
Category X…
etc…
If so you can check out and search info on Nested Repeating Groups.
https://widgets.airdev.co/widget/1472621296515x697398356394842200
They can be sluggish to load so sometimes it helps to get creative with your data, but early on it’s an easy way to get the functionality you want
Geoff | Wolfer Tech
Check out a Best Selling Bubble Template
Check out The Most Used Bubble Template (FREE)
