How to reset header element
Hi everyone,
I made some changes to the Header element workflow. The part where it shows Log in and Sign Out state. After I made the changes I deleted the header and now I can’t get it back to the original default format. It seems that the changes I made just messing around have stayed. My question is how do I reset my Header element or all elements back to default without creating a whole new blank page?
Thank guys
You could roll back the application to a point before you started messing with the header…but make sure you haven’t altered anything else or you will lose those changes as well.
Thanks I tried but the header element changes remained. Its so weird and frustrating because I have done a lot of other thinks building my page and seem like I’ll have to start over. I tried looking through setting but there are now reset options that I have came across.
