I am having the same issue. Can anyone pls help?
Continuing the discussion from Scroll Back on Floating group:
Please pick a subcategory to help organize the information. Thanks!
Also, the more context you provide with your questions (screenshots, link to an open app, etc.), the more likely you’ll get good help quickly :slight_smile:
Does your floating group has a scroll bar? Or you scroll it down with the page? How it works?
I’ve managed already. Thanks for your reply!
