What’s the best way to build a responsive and reliable messaging system for my school networking app? Should I use a platform like Bubble or create it from scratch?
Would you like me to tailor it for a specific platform
Yes i can help you with this, when are you going to be available for a better chat
If you don’t have any bubble experience, it will be a medium hard task. Bubble’s front-end already is a web-socket based real-time data updating structure.
If you can build a good database model and workflow structure, Bubble will be almost the easiest option. Don’t forget the data privacy, auth, and notifications, which will be mostly ready on Bubble. You need to spend time and effort for these if you go with custom code or AI assisted options.
For building an instant messaging system in Bubble, here’s a practical approach:
Database structure:
Create data types: User, Conversation, Message
Message fields: text, sender (User), timestamp, conversation (Conversation), read status
Conversation fields: participants (list of Users), last message, last activity
Real-time messaging:
Use a repeating group to display messages, sorted by timestamp
Set it to auto-refresh every few seconds (or use Bubble’s live update feature if on a paid plan)
Add a text input and “Send” button that creates a new Message entry
Key workflows:
When Send is clicked: Create new Message, link it to current Conversation, update Conversation’s last message
Display messages in a repeating group filtered by current Conversation
Show unread count by comparing message timestamps with user’s last seen time
For better performance:
Load only recent messages (last 50-100) instead of entire conversation history
Use privacy rules to ensure users only see their own conversations
Consider using a plugin like Pusher or Ably if you need truly instant delivery without page refreshes
This gives you a working chat system. You can then add features like typing indicators, file uploads, or group chats once the basics work.
