Is there any introduction video or documentation about using mixpanel from the very beginning, How to install the code script into your header etc or how to integrate it with bubble.
I can’t seem to find a beginners tutorial or anything similar about starting from scratch.
Well they might have changed their interface, but you shouldn’t have to go through this anyway. have you done the steps in Bubble? Then, run a workflow that sends an event and it should work.
The only steps I have done are Sign up to mix panel and then input my keys provided my mixpanel. I have tried running a workflow - "when Page is loaded and Current user is not logged in - send event to mixpanel - " I want to obviously record a page visit but cannot because I don’t know how to create events from the previous screen I showed you…
Just chiming in here for anyone who wants to go beyond just the basics. As emmanuel mentioned, you can start by entering the keys from Mixpanel in the plugins section. You will then be able to configure to send events and even the user id (for people profiles). Some of the actions that Bubble supports are here: https://bubble.io/reference#Plugins.mixpanel
Small plug but if you need help improving your Mixpanel implementation or you’re struggling to understand the reports, you can watch a free video series that will cover everything you need to know about Mixpanel. These videos are geared towards beginners who are just getting started with Mixpanel.
Hi @emmanuel , are you saying we just have to type the absolute same event’s name that we created manually into Mixpanel ? Or only create an event into Bubble then Mixpanel will understand that as it is the same name, it is the same event ? I’ll try.
Hey, if you (or anyone else who knows) is still here:
Mixpanel provides only two keys, namely the Token and the API Secret. Bubble requests three these two and in addition something called “API Key”. Any idea what to enter for the third one? Should I just use the Token twice?
@vovazk@apicedigital In Mixpanel, go to Personal Settings. Then, navigate to Projects and here you will find your Project token, API key, and API secret for each project.
