Here is API Documentation to support: I set up everything in the other system, but im not sure how to get the CallbackURL if it needs to be a GET response.
this Dialog will pop up, it gives you the link for your callback URL. This is JUST TO INITIALIZE AND SETUP YOUR RESPONSE DATA. Once your trigger successfully works, get rid of the last forward slash and initialize and you’re good to go.
Backend WF can be set as GET
However, you will not be able to use detect data. You need to set each key yourself. Just change “Trigger workflow with” … and click on add parameters. Add each key from the documentation. all of them should be of type “text”
