Hi gang. Is there a known bug or quirk with the checkbox input’s setting for “This checkbox should be checked?” When I use that setting on text fields, I get the red border and tooltip guidance. But my checkbox gets no such treatment and I’m able to check a button I shouldn’t be able to, i.e. the workflow proceeds. Any thoughts? Things to check? Thanks!
Hi there, @ThatFizzGuy… it’s not really possible to know what’s going on without knowing how you are using the checkbox, but give this thread a look and see if it helps.
Best…
Mike
Thanks @mikeloc. I’ve got it working now. I’m not convinced there isn’t a bug in there somewhere, as I’m sure I tried the combination of settings and checks I have now, but it’s working now so I’m movin’ on…
thanks again!
