Learning Stripe Integration with Bubble from India — Need Help with Account Signup
Hi everyone!
I’m currently learning Bubble and taking a course on integrating Stripe with Bubble. The course requires me to connect my own Stripe account to follow along with the lessons and practise the integration.
However, when I try to sign up for Stripe from India, I get a message saying that Stripe is available by invitation only in India.
I’m learning Bubble with the goal of becoming a freelance Bubble developer and eventually offering Stripe integration to clients worldwide.
I have a few questions:
  1. Is there a legitimate way for someone based in India to access a Stripe account for learning and testing purposes?
  2. Can I use Stripe’s test mode without having my own active Indian Stripe account?
  3. Has anyone from India completed a Bubble–Stripe integration course despite this restriction? If so, how did you practise?
I’d really appreciate any advice. I want to learn and practise the integration properly without misrepresenting my location or business details.
Thanks in advance!
I remember a few devs from India facing this in the Bubble reddit, you may wanna see there if they found a solution. I could be totally wrong but I think they ended up using a platform in India that does similar, and it may be worth it because it will support those first-party features that another country might use, like I know UPI is big in India!
Stripe has been invite-only for new accounts in India for a while, so you’re not doing anything wrong. A few legitimate ways to practise:
  1. Ask your course creator, or a client or friend abroad with a Stripe account, to add you as a team member with the Developer role. You get test-mode access without your own account. It’s also how you’ll usually work for international clients: you build into their Stripe account, not yours.
  2. Learn the same flow on Razorpay, which you can sign up for from India and use in test mode. Checkout, subscriptions, webhooks and refunds work in a similar way, and Indian clients will mostly want a local gateway with UPI anyway.
  3. Focus on the parts that carry over: customers, checkout sessions, subscriptions, handling webhooks in backend workflows, and never treating the redirect page as proof of payment.
I’d avoid signing up with another country’s details. Stripe can close the account later.
Thanks, man. That was really helpful.
Since Stripe signups are invite-only in India, I’d practise the same pattern with a gateway that has an open test mode, such as Razorpay (it has test keys and works with Bubble via the API Connector or a plugin). The skills transfer almost 1:1: create a checkout/payment session from a backend workflow, handle the webhook for payment success, and store the status on your Thing. Once you land a client with a Stripe account, you can just swap the endpoints and keys.
For practice, you can usually sign up for Stripe with a different supported country’s account only if you legitimately operate there, so I’d avoid workarounds. Most course exercises only need test mode keys, so ask the course author if a shared test account or sandbox is possible. Meanwhile, Razorpay has a Bubble plugin and works the same way (API keys, webhooks, a payment-confirmation workflow), so the skills transfer directly, and Indian clients will likely want it anyway.
