Navigation Question
You have a pretty complex app there, with a lot more data relations than most :slightly_smiling:
I have updated the Objective Page Workflow for you …
So when you create the Objective you store the Current Project on it as well.
Ok and so when I work with many layers like such
Activity would be Parent = Current Page Project
Subactivity would be Parent = Current Page Activity
Planning factor would be Parent = Current Page Subactivity
and then it should flow all the way up regardless of how many “layers” there are.
This makes a lot of sense. I will update the app to reflect this.
Yeah project management apps are always going to be complicated exchanges of information which makes for a more complicated app. I am sure it will have much more to it by the end!! Thanks for taking the time to review:)
No problem at all. Please shout if you need more help. Doing it in the app is much simpler :slightly_smiling:
Yeah, I know all about Project Manager’s and their complexities, I spent an hour today discussing Demand and Capacity planning issues with mine :slightly_smiling:
They use Sharepoint, my head may never recover !
