I have a pagination functionality that I have built using toolbox plugin, I am paginating from the data that I am getting from database. I have two arrow left and right that I use to move to next or prev page. How can I make sure that my arrow left and right of my laptop keyboard can also trigger the events (workflows). if there is any help or any information that I can rely on, I would appreciate it.
Hey @ntirandth,
Using Bubbleâs plugin âMouse & Keyboard Interactionsâ you can trigger a workflow when a user presses a key (or combination of keys).
If the field âKeyboard shortcutâ does not accept a keyboard shortcut, you might have to deactivate the experimental feature âCategorized types, datasources and operatorsâ on page Settings - Versions temporarily. Donât forget to refresh after (de)activating it.
Hope this helps,
Gerbert
MVP Design
Thank you gerbertdelangen, you helped me a lot. I am new to bubble.io and I did not know this plugin and how itâs used. Thank you
