I’m a bit baffled at what’s happening with my back end workflow:
The workflow aims at creating a copy of “cards” in the database, by copying 108 template cards. These template cards are marked by a unique number between 1 and 108 and their “template” attribute is “yes”.
My workflow then requires the initial index as input, which would be 1, then:
1. Finds the template card (template = yes and index = index)
2. Creates a new card using the information of the template card resulting from step 1. (This one is carefully marked as template = no).
3. Adds the result of step 2 to an array of cards in a “deck” item in another table of the database.
4. Calls the same API workflow, if the current index is < 108.
Now when I look at it again and again, I can’t see why it shouldn’t work. Yet, it copies all cards in duplicates. So I end up with 216 cards…
Step 1 in details:
Step 2 in details:
Step 3 in details:
Step 4 in details:
I checked that I have exactly 108 template cards (marked as yes), so it can’t be that the initial data is duplicated.
The workflow is completely linear: N calls N+1 one time unless N => 108. Even card n# 1 is duplicated. And when I look at the creation date of the cards, it’s not like 1, 2, … 108, 1, 2, 3, … 108, but rather 1, 1 ,2, 2, 3, 3, etc.
What could I have missed?
